April 12, 2019, 03:52 |
wind turbine efficiency
Ali
Rep Power: 8 |
Dear all CFD online members
I am Ali Azzam I am doing My Ph.D. in South Korea. My Ph.D. topic is about the design and simulation of low noise 10 kW horizontal axis wind turbine. I built a Matlab code based on the BEM theory to determine chord length and twist angle distribution along blade span. the main problem which I faced is efficiency. I used many different kinds of the airfoil (NACA 6412, NACA 4412, NACA 633-418, FX76-MP160, S809, S823, S823 and DU93-W210) for two values of Re (500,000 and 1,000,000). The efficiency for all these attempts was about (0.37-0.4). I would like to know how much the normal efficiency of the 10 kW wind turbine? and what do you think about this problem ?. Thank you in advance. |
Air Flow Analysis around a Wind Turbine | NightHawkRaven | FLUENT | 4 | August 12, 2014 17:18 |
simulating a wind turbine | s.q | FLUENT | 1 | October 17, 2013 08:11 |
Moving reference frame in wind turbine | kongl1986 | FLUENT | 0 | March 30, 2013 10:50 |
Vertical Axis Wind Turbine | atorninc | Main CFD Forum | 3 | March 6, 2013 04:38 |
FSI - Wind Turbine | AUN | CFX | 13 | August 29, 2012 16:44 |
