User User
Rep Power: 0 ![]() |
Hello,please i have a question regarding this error encountered in the installation of swak4foam on Ubuntu 18.04 version.
This script is rather crude. If it doesn't work try the steps by hand. And be sure to run it from the root of the swak-installation (as ./maintainanceScripts/compileRequirements.sh). Otherwise it probably won't work Bison already installed/compiled Bison successfully compiled Lua already installed/compiled Lua successfully compiled Add /home/user/OpenFOAM/OpenFOAM-5.x/swak4Foam/privateRequirements/bin to PATH-variable. The ./Allwmake-script will use this directory automatically Environment variable WM_PROJECT_VERSION unset This means that no OpenFOAM version is actived Please activate the OF for which you want to compile swak4Foam PS: I added this to ~/.bashrc source /home/user/OpenFOAM/OpenFOAM-5.x/etc/bashrc export WM_PROJECT_VERSION=5.x export PATH="/home/user/OpenFOAM/OpenFOAM-5.x/swak4Foam/privateRequirements/bin:$PATH" alias of5='source /home/user/OpenFOAM/OpenFOAM-5.x/etc/bashrc' and i added this to the bashrc file of OpenFOAM. I am new to linux. How can i solve it ? Thank you, |
Display Modes | |
[swak4Foam] difficulties installing swak4foam | newbie29 | OpenFOAM Community Contributions | 117 | June 16, 2021 03:11 |
OpenFoam Case crashes using swak4Foam | Miguel.Mendez | Main CFD Forum | 2 | March 23, 2021 23:42 |
source term in near wall cell | rajcfd | OpenFOAM Pre-Processing | 5 | February 1, 2016 10:31 |
[swak4Foam] Install swak4Foam on OpenFOAM1.7.1 on Ubuntu 13.04 | kobayashi | OpenFOAM Community Contributions | 2 | January 5, 2014 17:33 |
[swak4Foam] fails in parallel with -otherTime? | Phicau | OpenFOAM Community Contributions | 3 | June 26, 2013 13:00 |
