Co-simulation, map values to a non-convective boundary |
September 6, 2013, 07:01 |
Jimmy
Rep Power: 15 |
I'm trying to run a co-simulation where I get the heat transfer coefficient and reference temperature from the first fluid flow simulation. In the second simulation, I had planed to use these values for a solid boundary with thermal specification= environment (convection+radiation). But I noticed that the thermal specification changed from environment to convection when I activated co-simulation.
Do you have any suggestion in how I can map the values to a boundary in the second simulation and still use the environment condition there when runing a co-simulation? Update: The support told me that it will be possible in the next version, 8.06.002. But that is too late for me, so I will continue to do it "manually" with two simulations and two macros. Last edited by Jimmy123; September 13, 2013 at 04:32. Reason: Answer from support |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Numerical errors in nested domain with pre-calculated boundary values | Arnoldinho | OpenFOAM Running, Solving & CFD | 3 | April 4, 2012 10:31 |
boundary values | OFU | OpenFOAM Programming & Development | 4 | August 9, 2011 06:27 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 10:56 |
