May 16, 2012, 14:29 |
Mesh Genreralized Cylinder
David L
I attache a picture which is a simple pipe, but I have the same problem with pipe and elbows, I set Mesh Genreralized Cylinder but manager Cylinder no Found cylinder, "Generalize cylinder mesh not possible on boundary TUBO - Default because has non-smooth surface"....some idea about my error?
May 17, 2012, 11:49 |
#2 | |
Ryne Whitehill
Rep Power: 18 |
I am not 100% sure, but I do not think the generalized cylinder mesher can be used with a hollow tube like that. All of their examples show a full cylinder. edit: I tried it out, I was not able to get a generalized cylinder mesh around geometry like yours. I think youll have to use a typical volume mesh, or use the extrusion mesher if its a straight pipe section. Last edited by rwryne; May 17, 2012 at 13:38. |
May 17, 2012, 19:26 |
David L
the pipe and the elbow and inside a fluid, I do not use boundary interfaces, but it is necessary to have two superfaces pipe and elbow, with this way I have cylonders. before I have the superface pipe+elbow then I should have two superfaces.
cylinder |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 09:38 |
[ICEM] Injector Tube into a Big Cylinder - How to mesh? | Leepox | ANSYS Meshing & Geometry | 2 | November 25, 2011 10:45 |
rotating cylinder using sliding mesh | Tim Daly | FLUENT | 1 | November 9, 2008 23:02 |
ICEM block mesh with a ball in a cylinder tube | Li | CFX | 6 | August 11, 2008 05:44 |
mesh problem for cylinder | akr | FLUENT | 1 | January 29, 2007 23:43 |
