problem with interfaces
Old   June 7, 2012, 18:20
Default problem with interfaces
adam
sieginc. is on a distinguished road
I'm trying to simulate the convective cooling of a heat generating block in duct. I want the block to be defined as a solid, but I am having trouble creating the interfaces. I split the geometry by part curves, and then create another part based on the surfaces of the block. Then I send the two parts to regions, and define one as the air and one as the solid.
When I try to mesh I get an error that says one of the edges is shared by an odd number (3) of faces. At first I thought this meant I had somehow defined two faces on top of each other, and then when the cube meets the base of the duct that would result in edges being shared by three faces. However, there has to be the same surface defined in each region (one in air and one in solid) so you can select them both and define it as an interface, correct?
The system looks something like this:
sieginc. is offline   Reply With Quote
Old   June 7, 2012, 18:54
Henry Arrigo
Henry Arrigo is on a distinguished road
Hi
I think you should use separate meshes for each region instead of one mesh for both regions.
Henry Arrigo is offline   Reply With Quote
Old   June 7, 2012, 23:29
adam
Originally Posted by Henry Arrigo View Post
Hi
Unfortunately I don't think this will work. I've tried this in the past, and I've also read that you must have one conformal mesh in the whole geometry.
Old   June 8, 2012, 03:12
abdul099 is on a distinguished road
You're both wrong.
First, you can create a conformal mesh, using one mesh continuum. It works when your geometry preparation is done the right way. That's everyday business.
Second, you don't need a conformal mesh. It also works with a non-conformal mesh, but it will smear the solution a little at the interface. Conformal meshes are recommended, but not essential.
sieginc.: Can you have a look on the surface repair? Do you have error free parts when you check them independently? Do both of your parts share the same block surface? Did you create the interfaces prior to meshing?
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   June 8, 2012, 15:22
adam
Originally Posted by abdul099 View Post
You're both wrong.
I will check the surface repair. The parts share the same block surface. I'm assuming this is the problem? However, doesn't the same surface have to show up in each region so I can select both to form an interface?
Old   June 8, 2012, 16:17
Ryne Whitehill
rwryne is on a distinguished road
For people new to interfaces, definitely recommend "Split by topology". It gets everything set up for you!
rwryne is offline   Reply With Quote
Old   June 10, 2012, 14:35
Originally Posted by sieginc. View Post
... However, doesn't the same surface have to show up in each region so I can select both to form an interface?
Yes, you need the same surface in every part, so when you create regions from parts, the interface faces will show up as boundaries.
I also agree to rwryne, split by topology would be easier.
area does not match neighbour by ... % -- possible face ordering problem St.Pacholak OpenFOAM 10 February 7, 2024 21:50
conduction problem venkataramana OpenFOAM 3 December 1, 2013 07:30
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 19:42
Can I solve this problem by Fluent? Kai_kc FLUENT 1 October 27, 2010 05:29
Problem with Domain Interfaces hagupta CFX 13 May 5, 2006 12:41
