Need help: 7 times more Mass Flow out than in
Old   June 14, 2012, 11:31
Question Need help: 7 times more Mass Flow out than in
Simon
simonart7 is on a distinguished road
Hello!
I want to simulate the Battery-Cooling of a formula student car.
I implemented a radial fan, like in the rigid body motion tutorial
Inlet: Velocity (15m/s)
Outlet: Pressure
Implicit unsteady
Ideal Gas
K-Epsilon Turbulence
Gravity
Three Dimensional
Surface Remesher
Polyhedral Mesher
Prism Layer Mesher (2)
If I try Coupled Energy, the outgoing Mass Flow is going to be 7 times bigger than the incoming Mass flow.
It is still increasing.
Please help me!
Enjoy it.
Have a nice day!
( Please excuse my bad English)
simonart7 is offline   Reply With Quote
Old   June 14, 2012, 11:37
Simon
How can I put pictures in here?
Old   June 14, 2012, 11:38
Simon
Old   June 15, 2012, 03:33
husker is on a distinguished road
Try to monitor mass flow rate with manual reports of density and velocity.
Regards
husker is offline   Reply With Quote
Old   June 15, 2012, 15:42
abdul099 is on a distinguished road
A mass flow report at each inlet and outlet should be fine to judge the mass imbalance.
How long did you run it? What about your time step size? Is it small enough? What about the convective courant number? Residuals? How does the flow field look like, is it reasonable?
In my experience, the coupled solver needs a long time until a reasonable flow field has established. So although CD-adapco recommends the coupled solver when ressources are no issue, I would stick to the segregated solver when there are no high mach numbers involved. Or at least try to initialise as good as possible.
When the setup is right and you run it long enough, the coupled solver will give you the same mass flow in and out for sure (assumed, you're looking on average values over a long enough period).
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
fan, invreasing mass, mass flow rate, rotating
Convergence problem with target mass flow rate ADL FLUENT 2 May 29, 2012 21:11
Discrete Phase & Mass Flow Rate MagnusZeus FLUENT 0 December 2, 2011 17:57
Mass Flow Rate student87 CFX 4 January 2, 2010 04:45
mass flow Wenbin Song FLUENT 0 September 27, 2005 13:00
different mass flow rates michael FLUENT 4 February 21, 2005 03:48
