Intake
Old   November 2, 2012, 13:31
Default Intake
Flavio
jiujitsu is on a distinguished road
Hi
Has anyone had any experience with engine air intake box simulation?
I have set the intake boundary as pressure outlet for starters and the outlets as mass flow inlet, so I can set the mass flow on the outlet boundary and get the mass flow per filter on the inlet.
The only thing is I keep getting the message of reverse flow on the boundary, which I understand must be because the air is actually going into the boundary, but also there is no convergence to the model and I don't know if that can be addressed because of the following:
If I get the pressures this model generated (with oscilating residuals) and apply them to a pressure outlet boundary on the outlet now (changing from the original mass flow inlet), and change the inlet to a stagnation inlet, the model converges without any issue.
But I need both cases to check uniformity on the outlet and uniformity on the inlet.
jiujitsu is offline   Reply With Quote
Scramjet+Ramjet Intake Simulation mecbe2002 OpenFOAM 6 January 17, 2020 13:40
[ANSYS Meshing] Air flow through intake manifold zscheck ANSYS Meshing & Geometry 5 March 15, 2012 21:41
Discharge control in an intake ! ghmahtabi Main CFD Forum 0 March 1, 2012 14:09
Modeling of a airflow in a intake manifold Jack FLUENT 1 September 21, 2003 22:22
designing an air intake under gambit joseph guaragna FLUENT 0 November 20, 2001 06:21
