self intersecting geometry error
Like Tree4Likes
  • 1 Post By siara817
  • 2 Post By saisrikar
  • 1 Post By ank909
Old   October 16, 2012, 14:29
Default self intersecting geometry error
adam
sieginc. is on a distinguished road
I get this error after I assign parts to regions and I try to create a volume mesh. I have a solid object in a duct that is an assembly, and then the duct itself. I fill holes at the ends, and then extract the volume to get the air region. Then I send everything to regions. The interfaces are created as you would expect, but then when I mesh STAR says that the solid object is a self-intersecting geometry. I double checked the actual solid model and it does not have intersecting faces, so how could this be? I thought it was because I'm sending duplicate parts to regions but all I'm doing is extracting the volume, nothing more.
Here is a link to the sim file if anyone has the courage and patience to play around with it and tell me what I'm doing wrong:
http://www.sendspace.com/file/wr00au
sieginc. is offline   Reply With Quote
Old   October 17, 2012, 01:38
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
I think you need to work on your parts one more step before assigning them to a region.
You need to use Boolian functions. Please search in Help to find the solution.
sgrshukla likes this.
siara817 is offline   Reply With Quote
Old   November 3, 2012, 17:53
Srikar Sai
saisrikar is on a distinguished road
Hey,
Assuming the problem still persists, one suggestion I could give is to look specifically for "Pierced faces" in your geometry before volume meshing it. There should be none of them actually.
If you do not find any pierced faces with your initial surface, you can just try to remesh the initial surface ( if using surface remesher) and then run a mesh diagnostics on the remeshed surface (Representation- Remeshed surface - (right click) Repair surface).
In my experience I have found that some details of the starting surface are not captured if I give a size which is to coarse for the remesher. Thereby resulting in intersecting faces on some areas of the surface.
Also its an advice to always use the remesher before volume meshing any surface in CCM+.
ank909 and refay2006 like this.
saisrikar is offline   Reply With Quote
Old   November 21, 2012, 00:10
Anoop Kumar
ank909 is on a distinguished road
Hey hi ,
I am new to this forum, sry dont know how to message in this site,
let focus on problem , plz dont use volume meshing & surface meshing combined. First surface mesh (keep automatic surface repair off) then go for volume mesh .
in surface mesh give custom surface size to the boundary which are intersecting with ducts wall. Also cut the feature edge properly, then after surface mesh check mesh quality, if there are some priced face fix them manually , then go for volume mesh
i hope this will work.
regards
ank909
refay2006 likes this.
ank909 is offline   Reply With Quote
Old   November 22, 2012, 18:57
abdul099 is on a distinguished road
ank909, you can easily perform both steps at the same time. The precondition is that you've defined your surface right. If you haven't done this, it doesn't help to split it in two steps and "fix pierced faces manually".
Unfortunately I didn't find the time yet to have a look on the model, but I'm pretty sure that it can either be solved by a simple merge/imprint or the model built is just wrong and should be done right.
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
user defined function cfduser CFX 0 April 29, 2006 10:58
