Drag Coeffient monitor very high
Old   December 1, 2012, 16:09
Default Drag Coeffient monitor very high
anonymous
dwilson is on a distinguished road
I am modeling a NACA 0012 in 2D. I have drawn the aerofoil and the freestream box in NX and imported the CAD in. I then set everything up and I have set up two monitors for Cl and Cd in order to compare them to experimental data.
The Cl I have is around 1.2 which is a little high but the Cd i have is -3 and should be around 0.2. I have no idea why this is. I have set the reference values correctly I think in the monitor section (1.177 for density ref pressure is 101325 velocity is 6.943 force option is pressure +shear and the direction is set to components 0.9848,0.1736,0 as the aerofoil is simulated to be at 10 degrees. I have been looking for ages as to why the drag might be so high as I cant see anything wrong.
any throughts?
dwilson is offline   Reply With Quote
Old   December 4, 2012, 21:14
John
nomad is on a distinguished road
You should resolve forces in the streamwise(drag) and normal(lift) directions since your freestream is at an alpha.
nomad is offline   Reply With Quote
Old   December 21, 2012, 04:56
Niaz Ali Ahmed
niazaliahmed is on a distinguished road
Hi try choosing Standard K-Epsilon Low Re with adequate mesh resolution near the wall...
niazaliahmed is offline   Reply With Quote
coefficient, drag, monitor, naca 0012
drag coeff to high - kOmegaSST turbulence model RugbyGandalf OpenFOAM 5 February 22, 2011 02:35
high amount of drag coefficient. about 15????Is it okay? ndabir CFX 3 February 1, 2010 17:10
High drag coeff. estimated by Gambit+fluent M. suuri FLUENT 6 November 6, 2006 08:02
high drag value sulfi FLUENT 1 April 8, 2005 19:27
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
