Divergence of a 2d airfoil
Old   January 15, 2013, 12:25
Default Divergence of a 2d airfoil
fshak92 is on a distinguished road
I'm trying to do a rod-airfoil simulation by meshing in ccm+ and solving in OpenFOAM.For testing the validity of mesh in ccm+, i should have a converged solution in ccm but it does not converge.
You can see the general view of the geometry , as well as the magnified pictures of the mesh.
I've tested the wall distance around airfoil and cylinder in a wide range(10^-4 to 10^-7 ) and most of the turbulent solvers.But the residual(for turbulent parameters) goes up and i get very high velocity around airfoil and cylinder(something about 10^6) .
The inlet velocity is 100.
'velocity inlet' for the left middle boundary, 'pressure outlet' (right boundary) and 'wall' for other boundaries.
I would appreciate any idea,particularly on the mesh quality.
fshak92 is offline   Reply With Quote
Old   January 15, 2013, 16:22
abdul099 is on a distinguished road
Do you have flat cells in the prism layers near the walls?
We do three types of jobs here:
GOOD, FAST AND CHEAP
You may choose any two!
abdul099 is offline   Reply With Quote
Old   January 15, 2013, 19:20
Around airfoil or walls?
If you mean the first layer distance to airfoil, I've changed it from 10^-4 to 10^-7 , and as you know, it makes a quadrangle cells with very low width in contrast to its length.
but on the walls, the first layer distance is in the range of 10^-2 and only 5 layers have been used.Therefore it is not so flat.
But the strange velocity(about 10^6) is happened around airfoil and cylinder and not the walls.
Thanks in advance.
Old   January 16, 2013, 02:19
siara817's Avatar
siamak rahimi ardkapan
siara817 is on a distinguished road
Hi Omid
Do you have energy solver or you considered it to be isothermal?
If yes, try once to run with first order scheme and then if converged change to second order.
Good luck
Siamak
siara817 is offline   Reply With Quote
Old   January 16, 2013, 06:30
Originally Posted by siara817 View Post
Hi Omid
Hi
Thank you all for your consideration.
No i did not use any energy solver.
It seems the problem is related to mesh.
Old   January 16, 2013, 12:27
And these are the pictures for the new trimmer mesh.
I forgot to set an initial velocity.After set it to 50m/s, the residual became a little better.But after each iteration the turbulent viscosity of more cells are limited.(in the first picture,the red cells are the limited ones)
Old   January 17, 2013, 03:34
siara817's Avatar
According to your residuals it seems that it is converging. I think it is too soon to decide according some hundreds of iterations.
Good luck
Siamak
Old   January 17, 2013, 05:26
Thank you for your reply.
But the number of cells in which turbulent viscosity are limited,are increasing by iteration significantly...
The boundaries for 'top' ,'below' 'top-left' and 'below-left' are considered as 'wall',are they correct?!Because the problem is defined in a way that we have walls there.
But the velocity on those walls are nearly zero, Do you know how the turbulence models work there?
Old   January 18, 2013, 07:16
siara817's Avatar
Dear Omid,
It depends on the near wall treatment you have selected. Have you selected Two layer all y+...?
Good luck
Siamak
Old   January 18, 2013, 11:30
Dear Omid,
Thank you Mr. Rahimi
I used all y+ wall treatment. and it seems it distinguishes between the walls according their y+.
I refined the mesh in the region i had problem with turbulent viscosity and now this problem has been solved,,but still the residual for K is high(more than 1).
Old   January 18, 2013, 15:51
Thanks in advance.
I mentioned flat cells at "walls", and I'm pretty sure, your airfoil is a wall boundary. All other would not make any sense.
Now you say, the high velocity is located close to the airfoil boundary, where you HAVE flat cells (low width in contrast to its length). And you have even reduced the first layer thickness to an extremely low value (10^-7 is not suitable for an airfoil, 10^-4 or 10^-5 is a much more suitable range for this "low" inlet velocity).
So I suspect that's the main reason for your issues. And if so, please adjust your mesh resolution to create reasonable aspect ratios or increase your first prism layer thickness.
But even if I'm wrong, please check your y+ values at airfoil and cylinder since it should be in a reasonable range.
*Sometimes I wish this f... CCM+ solver wouldn't be that f... stable. In early versions it would just have been blowing up, but now it continues with nearly every setting - no matter if it makes sense or not...*
Low Speed Airfoil Mancusi FLUENT 7 April 3, 2014 06:11
Quarter Burner mesh with periosic condition SamCanuck FLUENT 2 August 31, 2011 11:34
Modeling Backflow for a 3D Airfoil (Wing of Finite Span) Josh CFX 9 August 18, 2009 11:31
Airfoil boundary condition Frank Main CFD Forum 1 April 21, 2008 18:36
Divergence problem when airfoil exceed pitch angle zonexo Main CFD Forum 2 April 4, 2007 04:22
