August 23, 2011, 03:56 |
Heat Exchanger
MM
Rep Power: 14 |
Hi everyone,
Has anyone simulated any heat exchanger (HEX) in star-ccm+? I have characteristic of a HEX from experiment; i.e. I have gas flow rate as a function of pressure and temperature (P,T) and I Would like to implement this in the programme. Any feedback? |
September 29, 2011, 01:39 |
ara
Rep Power: 15 |
there are options such as dual stram heat exchangers, change your region to porous media and then in physics options select dual stream heat exchanger. you will need two regions for the heat one for fluid flow and one for air.
select both regions, right click and create interface. this will create a region interface, then you can input your experimental data into that interface under interface tab. you will need to setup some conditions in regions too. like fluid mass flow and etc. I have done this many time. let me know if you need more help. THanks, Ara |
February 8, 2013, 04:15 |
MM
Rep Power: 14 |
After a long time I am back to the same question.
defining the boundaries and the domains are fine. However, I wonder if you used the 'Q Map' option to define characteristics of your heat exchangers. It asks for the mass flow rates of cold and hot streams and also the heat transfer rate in the HEX, which is fine - there is another option to specify 'cold inlet T' and 'hot inlet T'. However, these two values are not fixed and may vary with the operating condition in the HEX. Any comment on this? thanks. |
Display Modes | |
Heat Exchanger Model | sak2129 | FLUENT | 3 | September 26, 2017 01:29 |
Macro Heat Exchanger not selecting (Please help!) | zdeth | FLUENT | 2 | September 11, 2012 13:52 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
Heat Exchanger Simulation | tightaznbreaka | FLUENT | 0 | March 18, 2010 15:45 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
