February 25, 2013, 05:50 |
Part injector - Number of injection Points
Shane Farrell
Rep Power: 13 |
Im trying to calculate the air residency times of particles inputed into a room. Im using the lagrangian model and am using part injectors as my injector type. My inlets are set as the part fo the injectors. At the moment the injector is inputing 2100 particles into the room and its taking way too long to converge the results. I am wondering what setting do i have to change or reduce in order to reduce the number of injection points? Or does the surface area of my inlets affect this? I want to calculate the air residency times for maybe 100-200 particles. Thanks in advance |
February 25, 2013, 08:33 |
Petr Punge
you can use: 1.) Point inclusion probability less then 1.0 (less value -> less particles) 2.) Presentation grid as part injector region (10x20 points for 200 particles) Regards, Petr |
injector type, lagrangian, residence time |
Multiple Injection points in sprayFoam | kripalpariyangat | OpenFOAM Pre-Processing | 13 | October 29, 2022 01:22 |
CFD-Post: Polyline Export at Integration Points | minger | ANSYS | 4 | February 22, 2014 09:23 |
[ANSYS Meshing] Identical meshes in symmetric bodies in multibody part. | aarvay | ANSYS Meshing & Geometry | 2 | May 11, 2012 11:15 |
Monitor Points values in CFX-Solver | Silmaril | CFX | 1 | March 10, 2011 08:48 |
diesel fuel injection part Nozzle/Elment/D.valveVE | Michael weng | Main CFD Forum | 1 | April 4, 2006 21:46 |
