Zero radial coordinates found on non-axis face in boundary OUTLET
Old   February 20, 2013, 12:01
Default Zero radial coordinates found on non-axis face in boundary OUTLET
Vassilis is on a distinguished road
Hi!
I am dealing with an axisymetric turbulent jet. The problem is that when i try to initialize solution i get this message: Zero radial coordinates found on non-axis face in boundary OUTLET. I can't understand whats the problem, so if anyone can help me find a solution it would be great!
Thnx!
Vassilis is offline   Reply With Quote
Old   February 27, 2013, 05:27
Melih Meriç
mmntmflx is on a distinguished road
Hi Vassilis,
If you want to set up an axisymmetric model,
1. Converting plane(for convert 3D to 2D operation) have to be XY plane, that is, 3D mesh compress through the Z axis.
2. You have to choose correct axis for given geometry, i think your problem is here (setup boundary type).
mmntmflx is offline   Reply With Quote
[Other] mesh airfoil NACA0012 anand_30 OpenFOAM Meshing & Mesh Conversion 13 March 7, 2022 17:22
how to set periodic boundary conditions Ganesh FLUENT 15 November 18, 2020 06:09
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
8x icoFoam speed up with Cufflink CUDA solver library kmooney OpenFOAM Running, Solving & CFD 42 November 6, 2012 11:37
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
