May 8, 2013, 12:13 |
reason for divergence
Rohit Ray
I am running a simulation for a sphere with seam in air flow. when i rotated the seam and ran the simulation again, the solution is not converging. I did keep all the conditions same as the earlier case.
Can suggest me what to check if your Tke and Tdr aren't converging? |
May 14, 2013, 12:57 |
kw
Try selecting "Cell Quality Remediation" as an optional physics model.
It could also mean that you need to decrease your mesh size. |
May 29, 2013, 13:43 |
Kiran
Hi
Along with addition of cell quality remediation reduce the under relaxition parameter. Still if it does not work then change the boundary conditions to lower values. -kiran |
Reason for oscillating residuals | fayaazhussain | Main CFD Forum | 3 | August 21, 2014 10:31 |
[ICEM] What is the reason for this negative determinant? | kiddmax | ANSYS Meshing & Geometry | 6 | April 18, 2013 10:59 |
Reason for asymmetry in symmetric geometries | doubtsincfd | Main CFD Forum | 1 | June 10, 2010 08:13 |
Discussion: Reason of Turbulence!! | Wen Long | Main CFD Forum | 3 | May 15, 2009 09:52 |
Reason of divergence ? | Brayton | Main CFD Forum | 3 | December 2, 2000 22:34 |
