July 5, 2013, 02:45 |
X Y PLOT - Save the data
Sidam
hi all
i have created xy plot and when i run my simulation my velocity profile variation changes and i need to save the data of the plot for particular different iteration. How to save these data . Cos i am able to tabulate the data of last time step only. I need to save the data for every 50 time step... Like saving image file can we able to tabulate the data of the plot for the line probe for different time step??? |
July 5, 2013, 08:05 |
David
Rep Power: 13 |
It could be an eqsier way, but inthink you can do it with a macro. I know you can save an image of the plot but not sure about the data.
July 8, 2013, 09:16 |
KHB
Rep Power: 15 |
One other way is to autosave it to different file every 50 time step and then run through each one of them to extract the data in the plot! (with macro I suppose)
But I suppose there should be a better way to do it |
July 9, 2013, 08:35 |
Adam
Rep Power: 14 |
Try looking under Tools->Tables->XYZ Internal Table. You should be able to set an update trigger to export a table based on a line probe (at least in v8.02 you can, I'm not sure about earlier versions).
x- y plot |
How to extract data for contour plot? | Farid | CFX | 9 | April 3, 2017 19:07 |
[Commercial meshers] fluentMeshToFoam multidomain mesh conversion problem | Attesz | OpenFOAM Meshing & Mesh Conversion | 12 | May 2, 2013 10:52 |
Smallest binary file format to save large data | Zonexo | Main CFD Forum | 2 | June 2, 2008 20:25 |
How to save cell set post data in to a file | Negin | Siemens | 1 | January 27, 2006 03:41 |
How to save only a slice,not the whole data? | leon | Siemens | 3 | August 25, 2005 10:55 |
