Collapsing Prism Layers
Like Tree1Likes
  • 1 Post By fluid23
Old   April 24, 2020, 06:49
Default Collapsing Prism Layers
Jordan1997 is on a distinguished road
Hi there, I'm relatively new to Star CCm and am having trouble with some collapsing prism layers (See image attached). I have three separate surface controls for the wing (left), hinge (central) and fan (right), each with custom prism layer first cell heights according to their local Re number and custom number of layers.
Should I adjust these controls to all have the same prism layer settings to avoid this collapsing issue? Its quite a key area of interest to my results. Any help appreciated.
Jordan1997 is offline   Reply With Quote
Old   May 28, 2020, 14:59
SimulatorMaster's Avatar
Onur
SimulatorMaster is on a distinguished road
I'm not very experienced with surface controls yet I did experience this issue before. The problem generally lies within the prism layer total thickness and stretching. Try to either reduce the number of prism layer, or the above mentioned parameters. Though, if you reduce the prism layer number, you can adjust your stretching and thickness accordingly. Perhaps the best approach here is to reduce the total thickness.
If you are still having troubles switch to one surface control only for all surfaces and see if that makes a smooth mesh.
What I generally do is start with a very coarse mesh and adjust my prism layers accordingly. (Trial and error=D) Of course, it is always better to know the theory behind to obtain a good mesh to save time.
Good luck and have fun =).
Best regards...
SimulatorMaster is offline   Reply With Quote
Old   June 2, 2020, 11:59
Matt
fluid23 is on a distinguished road
Play around with minimum thickness percentage and layer reduction percentage in the prism layer mesher settings. You should be able to hold a better mesh around those corners, however, dropping some layers around a bend like that is not bad practice.
In my experience, trying to tailor local prism is a scale of diminishing returns. Depending on your turbulence and wall model, 1<y+5 and 30<y+<60 with the default all wall model is the sweet spot, but anything between 1 and 100 you ought to get good results.
Don't spend too much energy chasing down the y+ dragon, just get it into range and move on unless you have very specific reasons to dwell on it.
nakonakata likes this.
fluid23 is offline   Reply With Quote
Collapsing Prism Layers Jordan1997 Main CFD Forum 2 April 25, 2020 23:06
Prism Layers at Slip Wall to Non-Slip Wall Transition InfernoxCJC STAR-CCM+ 4 November 26, 2017 19:06
[ICEM] How to improve bad quality elements that are obtained after creating prism layers? Rohith Giridhar ANSYS Meshing & Geometry 2 July 11, 2015 18:04
[ICEM] Prism layers distorted near trailing edge of blade-Unstructured Mesh Rohith Giridhar ANSYS Meshing & Geometry 3 June 29, 2015 17:52
ICEM Prism Layer transition between surface with prism layers and one without TWaung ANSYS Meshing & Geometry 2 October 12, 2009 14:56
