December 14, 2013, 13:12 |
Internal flow- issue with pipe visibility
Dominic Rose
Im quite new to Star CCM+ only having done around 30Hrs, im working on a throttle design project and im trying to get the hang of running my own simulations. throttle issue.jpg Ive setup this simulation from using a CAD model and meshing the internal volume. ive applied a pressure to the outlet to draw air through the pipe. the simulation seems to be working fine as i can see the residuals and flow going in and out the ends. however i cant see the fluid as it moves through the body. I would be grateful if any could give me some clues as to what i might be doing wrong. Thanks |
January 6, 2014, 21:29 |
DSK
Rep Power: 12 |
One quick thing you can do is to make the body transparent. But that may not solve the issue.
You can use the surface option, right click on the surface and hide it. You can also go to the corresponding scene and play with hiding the parts or regions. Finally, you should try creating a plane through the body if you are interested in looking at a section. If you only want to look at the section, you should hide all the parts except the plane you created. Good luck! |
January 12, 2014, 17:51 |
Chaotic Water
Rep Power: 17 |
I guess Streamlines in Derived Parts would help
Display Modes | |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 11:14 |
steam flow in a pipe driven by a pressure gradient between inlet and outlet | SalvoCalvo | COMSOL | 0 | March 11, 2010 07:52 |
Turbulence in a pipe flow | JM | Main CFD Forum | 4 | December 21, 2006 05:04 |
Outlet BC for subsonic flow in pipe | andrea panizza | FLUENT | 6 | May 10, 2003 08:44 |
fluid flow fundas | ram | Main CFD Forum | 5 | June 17, 2000 22:31 |
