Aerofoil Modelling - Laminar approximation, transition and turbulence modelling. |
January 18, 2014, 05:49 |
Craig
Rep Power: 12 |
Hello all,
I was wondering if I could get some advice. I am modelling an aerofoil at various angles of attack and velocities. I ran some validation cases in 2D and 3D first using a Steady, Laminar model and then using the Implicit Unsteady Spalart-Almaras turbulence model. Both systems showed reasonable agreement of both lift and drag coefficient for angles of attack up to the plateau at stall condition. I have a few questions though (the aerofoil under consideration has roughly similar geometry to NACA 4412 or Clark Y): >> When is it appropriate to use a laminar approximation - could I perhaps assume that the separation of flow and development of a turbulent boundary is negligible for low (0-5 degrees) angles of attack? >> Am I right in saying that by using an Implicit Unsteady system with Spalart-Almaras turbulence, I am saying that the flow IS turbulent, and that the turbulence model in itself has no way of predicting the transition from laminar to turbulence. >> Would it be better, perhaps, to use a K-Omega model with the Gamma-Re-Theta transition model such that the CFD may predict transition to a turbulent boundary layer and the position of flow separation ... I tried this, the results seem okay but I don't get a 'trail' of low velocity flow behind the aerofoil as I do in the laminar or Spalart-Almaras case. Thank you very much! Asatorae |
January 20, 2014, 05:25 |
siamak rahimi ardkapan
Rep Power: 17 |
Have you tried to use some transition models? Check out the tutorial.
Good luck Siamak |
Display Modes | |
region of transition laminar flow to turbulence flow | farzadpourfattah | FLUENT | 2 | August 22, 2013 06:11 |
Code release: Flow Transition and Turbulence | Chaoqun Liu | Main CFD Forum | 0 | September 26, 2008 17:15 |
Transition from laminar to turbulence | Devang | CFX | 2 | June 24, 2008 02:27 |
modelling transition with v2f turbulence model | pablo | FLUENT | 0 | August 7, 2006 15:44 |
turbulence modeling questions | llowen | Main CFD Forum | 3 | September 11, 1998 04:24 |
