January 26, 2014, 20:40 |
Conjugate-Gradient solver did not converge!
sazrul
Rep Power: 12 |
Hi experts,
Currently I am running an Under hood Thermal Management analysis using Star-ccm+ v8.06.005. However, I am facing this error; 'Conjugate-Gradient solver did not converge' while I am trying to run the solution. Can anyone tell me what does this error means? What should I do to fix it? Your kind help is highly appreciated . Regards, Sazrul Kuala Lumpur. |
January 29, 2014, 08:19 |
#2 | |
Alexey
You may switch off CG and this message the following way. Select: Solver->Segregated Flow->Pressure->AMG Linear Solver->Acceleration method->None |
April 18, 2016, 16:43 |
#3 | |
sulaiman
Rep Power: 10 |
If I ignore the acceleration, I believe that will affect my simulation, Am I right? Is there a way to fix this issue and get convergence w/o ignoring acceleration? Thanks! |
April 19, 2016, 13:36 |
#4 | |
Alexey
If you don't want to ignore the acceleration then try to make experiments, for example decreas Under-relaxation factor. Solver->Segregated Flow ->Velocity->Under-relaxation factor and Solver->Segregated Flow ->Pressure->Under-relaxation factor Good luck! |
April 19, 2016, 14:02 |
#5 | |
sulaiman
Rep Power: 10 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM Running, Solving & CFD | 17 | December 3, 2014 19:41 |
Creating New Solver: For particle-laden compressible jets | sankarv | OpenFOAM | 0 | April 4, 2010 18:06 |
Can segregated solver be used for compressible flow? | Steven-GY | ANSYS | 0 | May 14, 2009 10:37 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
Poisson eq and conjugate gradient method | Gary Dantinne | Main CFD Forum | 2 | March 19, 1999 00:24 |
