Wave position in VOF
Old   January 28, 2014, 10:51
Default Wave position in VOF
Markus Frings
mftrombone is on a distinguished road
I am doing a VOF simulation. My gravity is in -y-direction. There are waves, which move in x-direction. I want to store the x-position of the top of the wave in a report during calculation. My first step was to create a maximum report for the y position of the liquid phase. But this reports only the height of the wave, but not the x position of this wave. Is there a possibility to get the coordinate at which the report value is measured?
mftrombone is offline   Reply With Quote
Old   February 2, 2014, 07:58
Ping
ping is on a distinguished road
the tricky issue here is that the wave moves so you need a way to limit the range of measurement from one wave trough to the next - eg knowing the wave velocity you have this
create a threshold that follows this wave (ie within a min and max x based on its velocity and the current time)
create a isosurface with the above threshold as the input using volume fraction of water as the scalar field
now you have a one wave isosurface
you just need to find the peak cells in this one wave - use the technique shown in the cd-adapco steve support portal article number 10265 called How can I calculate the location of a minima/maxima for a quantity?
ie
- create a max report called maxwave on that isosurface with scalar $Position[1] which is y of course
- then create a user field function called wavemaxcell defined as ($$Position[1] >= $maxwaveReport ) ? 1 : 0 - this means set its value to 1 if its equal or above the max wave report value, othewise 0
- create a threshold with the isosurface as the input part and wavemaxcell as the scalar field in 'all above' mode and set to 0
- create two reports to get x and y location - since you will have a few cells in your threshold best to use an average report probably - need to test
don't forget to use 2nd order time to model waves well
ping is offline   Reply With Quote
Old   March 22, 2014, 00:51
datouguaiguai is on a distinguished road
hello, i want to record the wave height on the fixed loacation as time goes. how should i do.
datouguaiguai is offline   Reply With Quote
Old   March 22, 2014, 03:05
Ping
see the cd-adapco steve support portal knowledge base article number 3923 called
is there a way to monitor the height of the water in my vof simulation
for one way and there are several other methods
Old   March 23, 2014, 22:15
would you like to send me the artical you recommended to me .my email datoujiangyin@sina.com
thank you.
Old   March 25, 2014, 09:06
Ping
you need to talk to your supervisor to get a login to the steve support site - it is great and far better than this forum for many subjects.
1. create an iso-surface at the air:water interface.
2. create a vertical section plane derived part, using the iso-surface as the input part – this results in a ‘line’ derived part on the water surface.
3. create another vertical section plane at right angles to the previous one and use that previous one as the input part – this results in a point at the intersection of these three parts – this is where we will measure water depth.
4. create a maximum report with that point as the input part and centriod z (assuming z is the up-down axis) as the field function. zheck the smooth option to avoid a stepped measurement.
5. create a monitor and plot from that report to store and graph the water depth at that location.
6. repeat the above if you want to measure at other locations.
you can also do a similar thing across a whole vertical plane or surface – ie get an average water height using an average report.
a simpler way to create a vertical line probe at the location and use a line integral report on this using vof of water as the scalar, but the output is relative to the base of the line probe rather than the water height.
Old   March 27, 2014, 07:34
3ks, i got it.
Old   March 27, 2014, 07:45
in step 3, why should i create maximum report?
Old   March 27, 2014, 08:27
i do what you told, but the result on the plot is a line,horizontal line,the value of z did not change as time pass away. why?
Old   March 27, 2014, 09:19
Ping
well first check that the last new derived part ie the point is on the iso-surface and follows it with time - it not you have not following the instructions properly
then is it simple reporting on the height of that point using a max report or a min report - these are just convenient reports to use. run the case for a white then stop and ensure the report values run manually match the wave height at that time. eg use the period (full stop) tool to measure the wave height manually at the measurement point
Old   May 26, 2015, 04:04
freeday's Avatar
freeday
freeday is on a distinguished road
Hello, does anybody could solve my problem?
I want to record wave height on x=0.4L (depend on tank). But my tank oscillates in X direction. I can't use either cross section between plane section and isosurface or point probes.
I'm really thanks full for your help.
freeday is offline   Reply With Quote
Old   October 21, 2015, 11:10
Ema40 is on a distinguished road
I apologize for the question, but I have a similar problem.
Do you know how to do a contour plot of water depths in an open channel flow?
Thank you!
Ema40 is offline   Reply With Quote
VOF wave getting damped. arun7328 STAR-CCM+ 16 July 8, 2019 15:06
Refinement for VOF wave arun7328 Siemens 4 January 21, 2019 08:57
vof method of wave height gtfeng STAR-CCM+ 2 June 8, 2013 02:32
5th Order VOF Wave miharbi STAR-CCM+ 3 May 2, 2012 05:51
HELP! UDF sinusoidal wave, VOF model, porous face! A8anato_psofimi FLUENT 2 November 10, 2009 14:42
