Lift force and Drag force calculation
Hi all,
This is my first post over here. For my MS thesis, I am working on a Clark Y aerofoil with experimental approach using an AEROLAB educational wind tunnel. I have set the problem in STAR CCM+ replicating the exact conditions in the wind tunnel. I did the run the simulations with good results showing the overall velocity and pressure profile. Now, I need to extract exact forces acting on the upper and lower surface of the aerofoil [I have already divided the surfaces into two different regions]. I have no idea how to go about it. How can I extract this particular data from the simulation? I need both normal and axial forces to calculate lift and drag forces and subsequently their coefficients. Any help is highly appreciated. I have very little experience with STAR CCM+. |
Hi!
Bring up the following in the the help section: Tutorial Guide > Compressible Flow > Transonic Flow: RAE2822 Airfoil Following the tutorial through should help :-) |
any way in the manual under the "tutorials" section you can find some examples! |
