How can I patch and define one of the phases in multiphase flow simulation |
May 4, 2014, 23:59 |
Rep Power: 16 |
I want to define an air drop in water. How can I define the circle (in 2D) flow for that? Thanks. |
May 7, 2014, 06:12 |
Ping
Rep Power: 20 |
in the normal way you create 2d cases in starccm+ - create it in 3d then convert the x-y face at z=0 to 2d
in your case you would have two parts - a block with a hole where you want the drop and the hole filled - ie a cylinder, which you turn into regions and mesh then convert to 2d you might be able to do it with imprinting a circle on the z=0 face so you get a separate boundary there - needs testing |
May 8, 2014, 01:21 |
Several Droplets
Rep Power: 12 |
Hi Ping,
I have also a question in the same subject. For one droplet, it might work but if you have several droplets (like 1000-10000) and you want to simulate them, do you have to create several parts? Thank you so much, Miki |
May 8, 2014, 05:35 |
Ping
Rep Power: 20 |
that would be very tedious so you would instead use the normal lagrangian parcel methods which are designed to inject millions of particles
amir2920 was refering to using the vof method for just one or a few drops and this can be initialized in a number of ways vof can be used for lots of drops but the cell size needs to be similar or better still much smaller that the particle size |
May 26, 2014, 05:20 |
Rep Power: 16 |
I defined the droplet using the field function. Do you know how can I specify an initial velocity for this droplet? Thanks,
June 2, 2014, 03:42 |
Ping
Rep Power: 20 |
since i assume you are still using the vof method to create a drop then you need to specify the velocity as an initial velocity in the physics and again this could be done as a field function for example applied locally to just around where the drop is located
Problem with cyclic boundaries in Openfoam 1.5 | fs82 | OpenFOAM | 36 | January 7, 2015 00:31 |
[Commercial meshers] Fluent msh and cyclic boundary | cfdengineering | OpenFOAM Meshing & Mesh Conversion | 48 | January 25, 2013 03:28 |
Cyclic Boundary Condition | Luiz Eduardo Bittencourt Sampaio (Sampaio) | OpenFOAM Running, Solving & CFD | 36 | July 2, 2012 12:23 |
[blockMesh] Cyclic BC's: Possible face ordering problem? (Channel flow) | sega | OpenFOAM Meshing & Mesh Conversion | 3 | September 28, 2010 12:46 |
[mesh manipulation] Using createPatch in place of couplePatches | sripplinger | OpenFOAM Meshing & Mesh Conversion | 8 | November 13, 2009 07:14 |
