Why I can't constraint the radial displacement in a periodic model?
Old   May 20, 2014, 23:30
Angry Why I can't constraint the radial displacement in a periodic model?
loveHL is on a distinguished road
My software is star ccm+ 7.04.
I new a periodic structure model, which is very simple:
The Models are as follows:
and the Boundaries are set like this:
I have set the axis.
However, when running the simulation, it is surprising that the displacement in the radial direction keeps increasing.
It seams that the periodic boundary did't work!
Who can help me? I have confused the problem for several days!
loveHL is offline   Reply With Quote
Old   May 21, 2014, 09:42
me3840 is on a distinguished road
Can you describe the problem you're trying to solve in detail?
me3840 is offline   Reply With Quote
Old   May 21, 2014, 11:43
The model is just a piece of solid ring, whose degree is 30° and material is graphite. on the bottom, the Stress/Displacement method is normal displacement, on the inner, the pressure is 0.2MPa, and others are free.
The reason why I modeled the simple model is that I just want to verify whether the periodic boundary condition constraints displacement in the radial and tangential direction. I found that the periodic boundary condition didn't work when I used it in other models.
periodic boundary, radial direction, star ccm+ v7
I need to model a positive displacement gear pump Richard Himmelmann Main CFD Forum 3 September 6, 2017 02:24
HELP! Periodic Problem foxer FLUENT 1 June 27, 2012 08:00
[ICEM] how to define periodic in icem ? mingersai ANSYS Meshing & Geometry 1 February 3, 2012 17:46
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
