Morpher moves two sides of boundary differently |
June 9, 2014, 04:57 |
Rep Power: 12 |
I'm trying to simulate a simple FSI Problem (basically a density change in a fluid that causes the surrounding solid to be morphed). I'm having a little issue however. The morpher: a) creates a motion without apparent reason. (there is neither change in density or pressure at the start of my transient case) b) it doesn't move both sides of the interface accordingly (it creates a gap between the two regions) Any ideas what might cause this? Unfortunately I'm quite new to CFD in general and had to learn Star CCM+ all by myself. Morpher Settings are: Explicit FSI, 0.3 URF for FSI, regionswise morphing, recompute interfaces on, morph from zero on, automatic thinning |
June 9, 2014, 10:20 |
Rep Power: 24 |
The motion isn't without reason. Activating the motion through the morpher is what allows the regions to morph. Make sure that is selected for both regions.
June 9, 2014, 13:31 |
Gajendra Gulgulia
Rep Power: 13 |
Hello Mwe
can you post a simple image of your problem with bc's and the entire physics model. Mr me3840 is correct. The flow fields are causing your geometry to be morphed unexpectedly. |
June 19, 2014, 05:04 |
Rep Power: 12 |
Sorry, since I'm working only part time on this issue, it took me a while to reply. I attached the physics models and (to me relevant) boundary conditions. If there's anything else you need to see, let me know and I will take another screenshot.
Thanks again for your help! |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 04:07 |
Boundary layer thickness on the sides of a civil aircraft | m1361 | Main CFD Forum | 5 | September 26, 2012 08:16 |
CFX doesn't continue calculation... | mactech001 | CFX | 6 | November 15, 2009 21:25 |
