Home > Forums > STAR-CCM+
wall y+ below one
Old   August 14, 2014, 05:08
Default wall y+ below one
hebeldebel is on a distinguished road
I am trying to simulate the heat transfer over a boundary with environment option. I checked wall y+ at it ranges from 0.00058 to 0.279.
I used K-Epsilon Turbulence , Realizable K-Epsilon Two-Layer and Two-Layer All y+ Wall Treatment.
As far as I can see, this should pose no problem, as I used All y+ Treatment and I am also below y+ << 1, therefore it should always use the u+ = y+ condition, right?
I do not use prism layers, is there a need to use them, when I am already well below y+ = 1?
Thanks for your answers
edit: In case I get y+ values between 5 and 30, all y+ will not compensate for it, right? It only switches between the logarithmic term and "u+ = y+", right?
hebeldebel is offline   Reply With Quote
Old   August 14, 2014, 12:30
Noah
npoutre is on a distinguished road
If you have a Y+ << 1 and are using "All Y+ Wall Treatment" than the solver is integrating to the wall and is not actually using any wall functions. All Y+ Wall Treatment is nice if you have some cells on the wall that are in the low, buffer, and high Y+ regions. It compensates for all.
There's nothing special about prism layer cells compared to other volume cells except you have more control over them. They are nice because you can control the surface growth rate and thickness, with more fidelity, to ensure your boundary layer is sufficiently refined.
Your Y+ is very low so you probably have decent boundary layer resolution, but just make sure your growth rate isn't too large.
npoutre is offline   Reply With Quote
Thread Tools
Trackbacks are On
Thin Wall Heat Transfer BC for rhoSimpleFoam swahono OpenFOAM Running, Solving & CFD 12 October 4, 2013 11:49
tmerge utility creates unwanted interface/walls comes in the final mesh dinesh2n@gmail.com OpenFOAM Other Meshers: ICEM, Star, Ansys, Pointwise, GridPro, Ansa, ... 11 January 20, 2012 07:23
Patches for OpenFOAM 1.7 on MacOS X gschaider OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 101 September 21, 2011 05:37
UDF for wall slipping HFLUENT Fluent UDF and Scheme Programming 0 April 27, 2011 12:03
Quick Question - Wall Function D.Tandra Main CFD Forum 2 March 16, 2004 05:29
