September 1, 2014, 03:01 |
Tke do not converge
Luca Moretti
Hi everyone,
I'm new in this forum and I'm currently trying to learn using star ccm+ vertion 9. I'm analyzing the infinite lentgh cylinder case, see the next figure for the geometry. the mesh settinggs are: base size on volume:1m target size on cylinder: 0.02m prysm layer thickness: 0.02m number of layers: 20 layers stretching: 1.5 I also used a refined volume with a base size of 0.1m behind the cylinder to better capture the wake. the boundary condition are: inlet: velocity inlet (10,0,0)m/s outlet: pressure outlet 101325 Pa top and bottom: wall (slip condition) sx and dx boundaries: periodic I tried different physics but more or less I obtained the same results. Mainly these are the settings: steady coupled flow constant density turbulent k-omega all with "auto-select recomnended models" activated. The problem is that th Tke converges until the 10th or 50th iteration depending on other settings I choose but then it diverges strongly. also the y-momentum does not have a strong convergence. Does anybody have some suggestions? Thanks |
September 2, 2014, 04:33 |
Rep Power: 11 |
A few suggestions:
1) Have you tried the segregated solver? 2) Activate "Temporary Storage Retained" in the k-omega solver and step the solution forward one iteration to visualize the TKE residuals in a scalar scene. This may give you some hints if there are localized issues with the mesh or the geometry. 3) Check the "Simulation divergence check-list" post in the knowledge base on the Steve Portal. |
Tke and Tdr goes sky high? Here is a differnt view to it. | feafan | STAR-CCM+ | 3 | July 23, 2014 01:15 |
k and epsilon were hard to converge in multiphase model of Fluent | Yanlong Li | ANSYS | 0 | January 2, 2013 05:25 |
Tke pike | rg12g09 | STAR-CCM+ | 0 | December 6, 2011 09:51 |
HELP !In relaxtion factor converge is taken or not | MANOJ KUMAR | FLUENT | 5 | September 22, 2005 04:16 |
Converge problem for multiphase flow | Jen | FLUENT | 4 | July 20, 2005 16:52 |
