Macro to loop over derived parts
Does anyone know how to loop over a specific type of derived parts (e.g. plane sections, line probes, etc) using a Java macro? |
you could loop over all the parts and then use an if statement to check the class of each part. Use only the ones you want.
Thanks kguntur, this works fine. :)
For reference, here is my understanding of your suggestion: Code:
Simulation simulation_0 = getActiveSimulation(); |
You are right. the if statement would look something like this.
String compare = "PlaneSection"; if (part.getClass().toString().contains(compare)){ //do something with the part } you can just print the class for all the parts to get your "compare" variable. |
