May 19, 2022, 07:12 |
Unable to remove non-positive volume cells.
Rep Power: 4 |
Hi all,
I am working on overset methodology for vehicle door closing. I am facing with the following error after certain time step. Error in metrics computation. The mesh may have non-positive volume cells. This may be due to an invalid imported mesh or to errors initializing an interface. Repair the mesh before proceeding. I have performed volume correction operations; 'remove invalid cells' (face validity<0.9 and volume change <1e-3, default for rest of the functions) along with 'split by function (zero face indicator)' and 'split non-contiguous' post volume mesh generation. On checking the solution file, I found few cells having face validity<0.6. The option of 'removing invalid cells' along with 'split by function' and 'split non-contiguous' are disabled in the solution file. Is there any other way to remove/resolve this. Regards, Bitty |
[snappyHexMesh] snappyHexMesh stuck when snap is turned on | yukuns | OpenFOAM Meshing & Mesh Conversion | 3 | February 2, 2021 13:05 |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 11:28 |
[snappyHexMesh] snappyHexMesh does not create any mesh except one for the reference cell | Arman_N | OpenFOAM Meshing & Mesh Conversion | 1 | May 20, 2019 17:16 |
cellZone not taking all the cells inside | rahulksoni | OpenFOAM | 0 | January 16, 2019 01:16 |
[blockMesh] Create internal faces as patch in blockMesh | m.delta68 | OpenFOAM Meshing & Mesh Conversion | 14 | July 12, 2018 14:43 |
