Pulsating inlet boundary
Like Tree1Likes
  • 1 Post By ping
Old   March 5, 2020, 22:55
Post Pulsating inlet boundary
Carl
Catho is on a distinguished road
Hi, I have been trying to run a (in my view) simple task but seem not to get it work .
For simplification, I have a straight tube with an inlet and outlet boundary. For the inlet (set up as "pressure outlet") I want to have pressure (sine wave) vs. time set up, basically a repeating pressure wave of pulsation.
For the pressure I specified a field function with ${Time}*sin(${AbsoluteTotalPressure}*$(TimeStep}) with:
Time = 50ms
TotalPressure = 1.0 to 1.1 bar
TimeStep = 5ms
For the outlet I used "stagnation inlet".
For model selection is used 3D, gas, implicit unsteady, segregated flow, gradients, turbulent, ideal gas, K-epsilon turbulence, Two-layer all y+, segretated fluid temperature.
The simulation itself is running but the pressure remains stationary and does not follow any wave like shape as if the field function is not considered although it was chosen. Any thoughts what could go wrong? Seems such a simply task to complete. Thanks a lot!!
(By the way, is it normal that the values in "field function" --> Definition --> preview are always back to zero after exiting that window?)
Catho is offline   Reply With Quote
Old   March 6, 2020, 01:10
Question
ashokac7's Avatar
Ashok Chaudhari
ashokac7 is on a distinguished road
Send a message via Skype™ to ashokac7
Can you plot velocity on cross-section and also mass flow monitors on inlet and outlet to see if any flow is happening in the domain. post the pics here.
Also I think giving Mach number is better way to give pulsating flow boundary condition.
And yes. For pressure range, it should show some profile in output window (previewing field function)
ashokac7 is offline   Reply With Quote
Old   March 28, 2020, 20:39
Ping
ping is on a distinguished road
if you want pressure to be a function of time then you need time within the sin function
cwl likes this.
ping is offline   Reply With Quote
Old   March 28, 2020, 22:21
cwl
Chaotic Water
cwl is on a distinguished road
First: ping is right, check your field function.
Second: Pressure Outlet for inlet, Stagnation Inlet for outlet .. why? 0_o
cwl is offline   Reply With Quote
Old   March 30, 2020, 02:55
Ping
to expand on cwl's reply - a stagnation inlet is the one to use as a pressure inlet and it is not good practice to use pressure outlets as inlets
Old   April 8, 2020, 07:43
wangh
ring1 is on a distinguished road
dear catho
i have the same question as you, I put the inlet as stagnation inlet boundary conditions and set the outflow conditions,the interesting is the flow is reverse, so I want to know why you choose the stagnation inlet boundary conditions as outlet ?
ring1 is offline   Reply With Quote
Old   April 11, 2020, 05:25
Ping
stagnation inlet is designed for cases when you are pretty confident there is a positive pressure drop across the domain and so reverse flow is not going to happen
so if you have a case where there is a likelihood of reverse flow then choose a pressure outlet - read the help on this boundary type for more details
pulsation, sine, steady-state, wave
Can I achieve better convergence? sheaker CFX 12 September 19, 2019 15:36
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 04:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 11:19
inlet velocity boundary condition murali CFX 5 August 3, 2012 08:56
