[Sponsors] | |||||
Giulio
Rep Power: 13 ![]() |
Hi guys,
I am invoking Your help as I am pretty much getting headackes on this Problem: I have a typical mesh of a steady state flow bench of an ICE. when I create the surface mesh everything goes fine with what seems a good mesh with no Errors detected, but if I build the Volume mesh it stops with this error: Signal: SIGSEGV: memory access exception particularly it does so in the Phase of Inserting Interior Vertices or Generating Volume Mesh, (directly successive). I donīt know why and what could I do as I already did many cases on this test bench but I am getting Trouble with the valve very near to the valve seat (I had to deactivate the Surface Wrapper). Please help G PS: I donīt know why restarting the PC it did the volume mesh, but now, if I prepare another case I have the same problem Last edited by the_end90; September 9, 2014 at 10:38. Reason: update |
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 03:53 |
| [blockMesh] non-orthogonal faces and incorrect orientation? | nennbs | OpenFOAM Meshing & Mesh Conversion | 7 | April 17, 2013 06:42 |
| 'Tetrahedral meshing has failed for volume...' | Murat | FLUENT | 5 | February 19, 2011 05:22 |
| On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
| volume meshing | nikita | FLUENT | 1 | July 3, 2003 02:25 |
