Mesh at a sharp corner
Old   September 5, 2014, 07:19
Question Mesh at a sharp corner
crevoise is on a distinguished road
Hello
I am getting some convergence problem due too a sharp corner on my geometry. More precisely, the turbulent dissipation rate get residual up to 10, while getting high value at that corner on few cells.
I guess my mesh at that corner is not the best (see attached), and I wanted to know if someone has some hint on how to improve it.
Thank a lot for any help
crevoise is offline   Reply With Quote
Old   September 5, 2014, 12:51
Default Cell quality remediation
Gary
Gary6891 is on a distinguished road
Did you try Cell quality remediation option? Or your initial values might be worth rechecking
Gary6891 is offline   Reply With Quote
Old   September 5, 2014, 13:47
cwl
Chaotic Water
cwl is on a distinguished road
Finer mesh based on Volume Shape might help
cwl is offline   Reply With Quote
Old   September 8, 2014, 08:49
Thanks a lot for your answers.
I did tried the cell remediation, but did not realy influence that much.
However, as suggested, I checked my initial values and modified them with some values obtained aith some not well converged computations. Thus the residuals are much better. (see pictures)
I have then a question, to get more light on this as I am not an expert.
I was thinking that the inital values should have an influence on the 'rapidity' of the convergence, but not on the accuracy of the solution.
However, but having good inital values shows that the solution is converging properly, while wrong values do not allow convergence to accurate solution.
So it seems that the initial values have an influence on the final solution, which sounds strange to me.
Am I wrong in my understanding on solution independency toward initial values?
Thanks again for your help and your info.
Old   September 17, 2014, 11:35
cwl
Chaotic Water
In case of convergence of the simulation - changing initial values should result only in rapidity of convergence; but convergence itself is highly affected by Solver Settings like CFL, Under-Relaxation Factors.
The convergence in terms of (low) Residuals is not a strict convergence; i believe that simulation run can be considered complete, converged and ok - when mass and heat (at least) ballances (computed using Reports and Field Functions) do converge, - and that i consider a criteria.
Old   September 23, 2014, 22:38
me3840 is on a distinguished road
Don't touch the URFs or use cell quality remediation. The problem is your mesh. Your prism mesh is far too coarse, you only have 2 prisms, and it looks like it's not thick enough. What's the y+ on that surface? It's probably through the roof. Your boundary layer looks like it's well outside the prism layer on that cut.
me3840 is offline   Reply With Quote
corner, meshing, turbulent dissipation
[ICEM] Mirror Mesh | Delete duplicate mesh pythag0ra5 ANSYS Meshing & Geometry 6 November 19, 2013 07:35
[snappyHexMesh] sharp edges non conformal Mesh ynos OpenFOAM Meshing & Mesh Conversion 4 October 6, 2012 11:24
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[snappyHexMesh] external flow with snappyHexMesh chelvistero OpenFOAM Meshing & Mesh Conversion 11 January 15, 2010 19:43
Icemcfd 11: Loss of mesh from surface mesh option? Joe CFX 2 March 26, 2007 18:10
