September 29, 2014, 05:34 |
residual for naca 4412 seem wrong
Daniel
Rep Power: 11 |
hi
im doing a simulation for flow around airfoil NACA 4412. but the residual seem not going to be stable.it keeps going up and down. the residual for angle of attack -5,0 and 5 is stable.but for the -10,10 and 15 is like the pic given. is anyone can help me with this? |
September 29, 2014, 17:48 |
Rep Power: 24 |
While your residuals in magnitude seem high (this is probably related to the grid), the oscillations you see are probably the result of a transient phenomenon. Are you running steady-state? If so, residuals like this for a high angle of attack may be expected. Can you post images of your grid and give some information on the physics regime?
September 30, 2014, 01:18 |
#3 | |
Daniel
Rep Power: 11 |
-gradients -2D -segregated flow -steady -ideal gas -inviscid do you mean grid as the mesh?if so,here it is.. |
October 1, 2014, 16:43 |
Rep Power: 24 |
You're running the physics inviscid but it looks like you have a nice boundary layer mesh? Why is that?
What mach number is this at? |
October 8, 2014, 05:01 |
David
Rep Power: 14 |
First of all, are the results good enough? say Cd,CL.
If the results are good than have a look at the absolute residuals value. If the absolute residuals value is small enough then don't pay too much attention to the residuals. |
October 8, 2014, 06:32 |
#6 | |
Daniel
Rep Power: 11 |
it was running with 3,000,000 reynolds number and that makes it as 43.81m/s as the velocity.. any suggestion?maybe i should do something else in physics or something.. |
October 8, 2014, 06:35 |
Daniel
Rep Power: 11 |
the results are not good enough apart from angle of attack -5,0 and 5.others than those are not.
October 8, 2014, 06:44 |
David
Rep Power: 14 |
reduce your URF and see what happens.
BTW, did you use the same mesh for different AOA? Judging by your mesh, I suppose that you used the same mesh and changed the direction of incident wind, right? There is a tutorial in ccm+ help file which tells you how to use overset mesh to test the effect of AOA. (You do have to use overset mesh, however, you will have a brief idea about where you need more meshes.) Since you can get good result for some AOA, I would say it is caused by mesh most probably. |
October 8, 2014, 07:26 |
#9 | |
Daniel
Rep Power: 11 |
yes i am using the same mesh for different aoa.is it something wrong with it? where i can find the help file?if i may ask that |
October 8, 2014, 07:32 |
#10 |
Rep Power: 11 |
URF = Under Relaxation Factor
October 13, 2014, 02:22 |
#11 |
Daniel
Rep Power: 11 |
i got the lift coefficient right, but why the drag coefficient seem wrong and quite different from the theoretical?
i used the direction in the report as (1,0,0) or should i change to another value? |
buoyantSimpleFoam and watertank | Tobi | OpenFOAM Running, Solving & CFD | 100 | December 18, 2022 08:15 |
Simulation seems to converge but crashes suddenly | xxxx | OpenFOAM | 16 | September 12, 2014 08:07 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Low Mach number Compressible jet flow using LES | ankgupta8um | OpenFOAM Running, Solving & CFD | 7 | January 15, 2011 13:38 |
