Star CCM+9.02 Problem
Hello
When I Running Star CCM +9 ,I Frequently Faces with This Error. Please Guide me. Thank You Exception ClientNotifyHandler A Java.net.SocketExeption has occurred. Log: java.net.SocketException: Connection reset at java.net.SocketInputStream.read(SocketInputStream. java:189) at java.net.SocketInputStream.read(SocketInputStream. java:121) at sun.nio.cs.StreamDecoder.readBytes(StreamDecoder.j ava:283) at sun.nio.cs.StreamDecoder.implRead(StreamDecoder.ja va:325) at sun.nio.cs.StreamDecoder.read(StreamDecoder.java:1 77) at java.io.InputStreamReader.read(InputStreamReader.j ava:184) at java.io.BufferedReader.fill(BufferedReader.java:15 4) at java.io.BufferedReader.read(BufferedReader.java:17 5) at star.base.neo.NeoProperty.readNextChar(NeoProperty .java:670) at star.base.neo.NeoProperty.input(NeoProperty.java:4 40) at star.base.neo.ClientNotifyHandler.run(ClientNotify Handler.java:453) |
This looks like an issue with your license server. When does something like this occur? Also, you didn't provide a lot of details related to how this issue occurs. Can you explain what you were doing when this occurs?
I ran into this same exact error message recently on v11.02.009.
What I did was try to "load surface mesh" and tried to import a solidworks part (a .sldprt file) which can't be done. I needed to open a parasolid .x or binary parasolid .x_b file but I kept misclicking. |
