Conjugate Heat Transfer- Meshing
Like Tree2Likes
  • 1 Post By kguntur
  • 1 Post By Bust
Old   November 10, 2014, 08:14
Default Conjugate Heat Transfer- Meshing
skapetan is on a distinguished road
I'm trying to analyze a CHT problem on an exhaust system, but there just some meshing facts where I'm not sure about how to handle it. So I wanted to discuss that issues with you and get your help.
-my case consist of a small solid region ( 4mm thickness )
It's clear that I need a Solid and a Fluid Region to setup CHT (+Interface between Regions). I wonder how to mesh this regions. For an accurate solution its recommended to have a conformal mesh between Fluid and Solid.
First option is to generate one mesh continuum and second option is to generate two mesh continua for each region.
So is it possible to achieve a conformal mesh via an contact interface if I chose option two?
The reason why I want to mesh with two continua is because of my thin Solid Region. Therefor I want to use the Thin mesher.
What do you recommend for my case? Is it useful to use the Thin mesher? Or should I mesh with 1 continuum and costumize my Poly-mesh in the Solid region?
Thanks for you help.
skapetan is offline   Reply With Quote
Old   November 11, 2014, 02:53
kris
kguntur is on a distinguished road
You can get a conformal mesh using a single mesh continuum. Using one mesh continuum for multiple regions is compatible only for polyhedral mesh. So use that along with embedded thin mesher and you can get a conformal interface. Make sure you have created the interface before meshing.
However, if you want to use trimmer for the fluid region, then surface mesh the solid and fluid regions together and then generate the volume mesh. This will not give you a conformal interface, but it will give almost 100% interface.
Hope this helps.
skapetan likes this.
kguntur is offline   Reply With Quote
Old   November 12, 2014, 05:35
Bastian N.
Bust is on a distinguished road
As kguntur said: 1 continuum and the Embedded Thin mesher should be the way to go.
I did exactly the same once and a there are basically no restrictions. Remember to turn on the "grow prism layer" option for your interfaces, you can then deactivate the prism layers again in the solid region.
Cheers!
Bust is offline   Reply With Quote
Old   November 18, 2014, 08:58
Thank you for your fast response.
Is there any option where I can check if i have a conformal mesh or not?
Basically it would be possible to use the two mesh continuum with the consequence being a bad accuracy for my solution or no convergence, is that right?
Old   November 18, 2014, 09:15
kris
Once you create your interfaces and generate the volume mesh, right click the interface and click initialize. If it is a conformal match, you should be able to see that in the output window.
Two mesh continuum will not give conformal mesh. It is not all bad. I have used that successfully for many simulations. However, conformal mesh has fewer errors.
Old   November 19, 2014, 06:23
Thanks a lot for this very helpful informations.
Old   November 20, 2014, 10:17
I disabled prism layers at the solid region and activated "Grow Prisms from Interface" at the Interface Prism layer Option.
If you take a look at this picture 3D plane.jpg you can see that prism layer are only generated in the Fluid Region of the Ribed channel.
What I'm wondering about is if there should be prism layers at the wall of my channel and around the ribs if I convert my mesh into a 2D mesh. As you can see here there are no visible prism layer around the ribs etc. 2D Mesh.jpg .
Do I have to change some options for my 2D mesh?
Thanks in advance.
Conjugate heat transfer in a counter flow heat exchanger abhijithmohan FLUENT 2 March 23, 2014 09:10
heat flux on solid surface in conjugate heat transfer skuznet OpenFOAM Pre-Processing 0 December 10, 2013 01:36
[Other] Meshing Techniques for Heat Transfer with Cube Shaped Objects cbritan OpenFOAM Meshing & Mesh Conversion 4 March 2, 2011 02:12
Conjugate Heat transfer in CFX ksp1717 CFX 11 December 10, 2010 23:07
Conjugate Heat Transfer of Motorized EGR enr_venkat CFX 1 October 12, 2010 19:17
