boundary condition and MRF
Old   November 12, 2014, 09:42
Default boundary condition and MRF
Daniel
Daniel4 is on a distinguished road
hi guys
i have some problem setting up the boundary condition for my simulation.can you give me suggestions or guide me through it.
i want to simulate a fan and also a ducted fan. i imported the geometry and did the mesh.but how can i set the boundary condition so the fan can rotate at certain RPM.should i make the geometry as a big cylinder in CATIA(while creating the geometry of the fan) as for the velocity inlet and pressure outlet and etc?
how to do the MRF on this simulation?
attached is the geometry i imported and also the mesh of my geometry.
thanks
Daniel4 is offline   Reply With Quote
Old   November 13, 2014, 02:00
Daniel
i tried to edit in 3D cad and do some sketches to make the boundary condition,but when i try to generate volume mesh,it says the surface is not closed.
but when i do a solid extrude,it will make my fan disappear.i just dont know what to do now.
anyone please help me or give me any suggestion!!
Old   November 17, 2014, 14:02
Muzz is on a distinguished road
There is a tutorial in the Star-CCM+ documentation which should help you with this particular problem. It deals with the operation of a marine prop in open water. You should be able to apply some of the same principles and it will also assist you with the MRF problems you're having.
If you're getting an error that states a surface is not "closed and manifold", it usually means that there are some issues with your imported CAD model, from my experience. You'll need to look into "surface repair" methods from the documentation as well.
Muzz is offline   Reply With Quote
Velocity boundary condition in an enclosed wind tunnel yanyanh OpenFOAM Running, Solving & CFD 1 May 7, 2014 18:03
Periodic Boundary Condition on Impeller Section rvl565 FLUENT 1 August 7, 2013 17:46
Centrifugal pump boundary condition njundale FLUENT 1 August 5, 2012 12:17
Centrifugal pump boundary condition Mohankumarg12 FLUENT 2 August 9, 2011 01:04
interior boundary with MRF mlbontbs87 FLUENT 0 December 15, 2010 14:14
