[Sponsors] | |||||
Jakob Fischer
Rep Power: 13 ![]() |
Hey Folks,
I want to investigate drag and lift of a few three element airfoils. In order to check the validity of my results I did a simulation of a design I have some former results from. Now the clue: My results vary from those I already have from another simulation. As you can see in the pic, my simulation (lower one) produces stall after the second blade, while the upper one doesn't. Its the exact same model in a more or less same dimensioned windtunnel, with moving floor. My mesh is as accurate as the mesh from the original, I use same turbulence model (K-epsilon) and same other physiks and meshmodels. After 1000 iterations in steady I switch to unsteady and do another 6000 iterations. My values for drag and lift coefficient converged pretty well over the last 2000 iterations. What are your first thoughts, when you see the different flow behaviours? Any tip is welcome ![]() Best wishes, Jack Edit: Just rememberd stuff from classes and thought about the courant number. I'll check the cell size and timestep in unsteady mode, maybe that's my issue. Last edited by JackFischer; December 3, 2014 at 05:51. |
Rep Power: 26 ![]() |
Those meshes are far too coarse in the downstream area, you can see the diffusion really easily.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [ANSYS Meshing] Inflation - Airfoil Meshing - Divergence problem | dalecooper | ANSYS Meshing & Geometry | 0 | July 19, 2013 08:04 |
| [ANSYS Meshing] Meshing a circular arc airfoil with close boundary | Benrode | ANSYS Meshing & Geometry | 0 | July 6, 2012 19:34 |
| [Other] Ansys meshing airfoil and / or compressor blades | baw192 | ANSYS Meshing & Geometry | 8 | September 23, 2011 01:43 |
| Multi element wing 3-d problem: trailing edge resolution | sriram042000 | CFX | 2 | March 13, 2011 06:44 |
| Oscillating Airfoil - Dynamic meshing or user-defined velocity profile. | DarrenC | Main CFD Forum | 5 | July 19, 2010 23:33 |
