[Sponsors] | |||||
Rep Power: 13 ![]() |
Help>
Hi guys, im using the starccm+ to oscillate a cylinder in x direction, the period is 20s, whole physical time is 100s. the images show cylinder stop moving at 68.89s, but the plot shows it still moving, so im confused now, where am i wrong? P.S. DFBI> general planar motion>2*sin(0.314*$Time) Using update in the scalar scene to export the images The physical time in the images afterwards the 68.89s is the same. 68.89s Cheers Jason |
Rep Power: 26 ![]() |
What version are you using? This is likely a consequence of the combination of your hardware and how often you render the image. If you render the image fewer times per several timesteps, it will probably start working again.
The server doing the calculation can get ahead of the client which renders the graphics - so much so that the client gets 'stuck' rendering the same thing over again. In newer versions the client will force the server to wait until it's completed rendering images. |
#3 | |
im using the version 9, The i set time-step size to 0.01s and the other settings are default under the updates. so how could i force the server to wait? cheers Wei |
You need to increase the frequency that you save images at. Look a the properties for each scene.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| AMI speed performance | danny123 | OpenFOAM | 21 | October 24, 2020 05:13 |
| Multiple floating objects | CKH | OpenFOAM Running, Solving & CFD | 14 | February 20, 2019 10:08 |
| Help for the small implementation in turbulence model | shipman | OpenFOAM Programming & Development | 25 | March 19, 2014 11:08 |
| InterFoam negative alpha | karasa03 | OpenFOAM | 7 | December 12, 2013 04:41 |
| plot over time | fferroni | OpenFOAM Post-Processing | 7 | June 8, 2012 08:56 |
