Problem with Constrained Plane
I am trying to get the averaged velocity in an axisymetrical nozzle inner section and for that, I created a 2D mesh and a constrained plane spaped to it. But the result shows 0 velocity on the constrained plane and that I looked up in the help and I found that to use a constrained plane, a volumic mesh is necessary. :( But what I need is a 2D axisymetrical mesh and that confused me alot. Anyone can help me please? Thanks! :) Jishen |
I'm really confused as to what you're trying to do. If you have a 2D mesh, that mesh is already a plane. Why do you want to make a plane from that plane?
Unless you are using the very latest version of Star-CCM+, it doesn't have a 2D mesh option. The volume mesh is basically your 2D geometry extruded so that it has a thickness, then the constrained plane cuts through the voume mesh and extracts a their 2D mesh.
However, that changed with v9.06.009 or maybe v10. |
Hi Romarius
more over constrained planes are better to visualize the scalar or vector plots or get values where the flow enters a new zone and you don't have an interface to get the values. A constrained plane hanging in the middle of a volume (or surface in your case) continua will not yield conservative values. |
