December 13, 2021, 19:25 |
Parallel Meshing
Bal
Rep Power: 4 |
Hi all,
I'm trying to test parallel meshing on my computer. So I've enabled the "parallel" option and run the Java script. The mesher models that I'm using are polyhedral, prismatic and surface remesher. I'm running the case on 12 cores & am not really that impressed with the performance. The license that my university has is an educational license. What could the reason be? What to do? Any advice? I can also test the star case on a higher number of cores in the HPC (linux system). Anyone has tried to run the meshing java script on a linux system? I'm also worried that increasing the number of cores does nothing???!! Thanks!! |
December 13, 2021, 20:01 |
Lucky
Rep Power: 65 |
The parallel meshing option isn't a placebo button if that's what you are asking.
Use some system monitoring tools (e.g. task manager in Windows) to check the performance of your system. Check the cpu usage. Check your ram usage and throughput. Look for bottlenecks. If you run out of RAM for example, expect the meshing to take forever. What kinds of timescales are we talking about here? If your mesh takes more than an hour than you probably exceeded some physical limit. |
December 13, 2021, 22:26 |
Bal
Rep Power: 4 |
Meshing has been ongoing since 12 hours.
December 14, 2021, 03:59 |
Mesh Linux Error
Bal
Rep Power: 4 |
So, i was able to create a mesh in star ccm in windows*using a .java file. However, when I tried to do the same in linux*system, there was an error saying that the macro file couldn't be opened
*Any thoughts? |
December 14, 2021, 04:19 |
Lucky
Rep Power: 65 |
Are we debugging parallel Star here or is this your first attempt at meshing anything, like ever?
If it takes more than an hour on a 12-core build then you probably ran out of RAM. Have you checked the task manager!? Or try using coarser settings.... An hour of meshing on a 12-core build is gonna grab about 100GB of RAM. If it says the file could not be opened then it means just that. It couldn't find the file or the file couldn't be opened due to the user not having read permissions (very unlikely). If it found the file and the .java was absolute garbage inside, it would give you all sort of errors with bad declarations and such. If you give it a blank .java macro, it will do nothing. |
December 14, 2021, 04:28 |
Bal
Rep Power: 4 |
To start with, I'm a new user of star ccm and also new to the CFD world. I'm a chemical engineering student, with almost no programming background.
I thought that I can learn in this forum by discussing with experts who can communicate their "wisdom" :P I opened the task manager and it seems that the memory usage is high. The mesh is running though, but it's taking alot of time. |
December 14, 2021, 15:11 |
#7 | |
Bal
Rep Power: 4 |
The error with the macro file, was as you mentioned, a simple one.
It's related to the names of the files & whatever is mentioned in the linux configuration script. This has been resolved. Thanks!! Quote:
December 14, 2021, 16:39 |
#8 | |
Lucky
Rep Power: 65 |
Look at your cpu usage and make sure all 12 cores are running at 100%. That means it is actually meshing. Look at your RAM and make sure it's well below 90%. If you ran out of RAM then Star will keep trying to use the page file before throwing an out of memory error, which can take a very long time. If more than a few of your cores are sitting idle then it's not doing anything. I'm going to keep echoing this statement unless you tell me your machine has 1TB of RAM of some crazy amount. When you get Star running on your cluster, all the same applies except you'll be using not Windows Task manager. |
December 15, 2021, 00:21 |
Thank you
#9 |
Bal
Rep Power: 4 |
Thank you. I did monitor the performance & exactly as you suggested, the RAM isn't sufficient. It just doesn't show this error right away, like you said.
December 15, 2021, 01:55 |
#10 | |
Matthias Fitl
Rep Power: 17 |
Linux: /home/username/starccm/testcase.sim Windows: C:\User\username\starccm\testcase.sim And yes RAM could be an issue, set the mesh to coareser values. |
[Gmsh] gmshToFoam generates patches with 0 faces and 0 points | Simurgh | OpenFOAM Meshing & Mesh Conversion | 4 | August 25, 2023 07:58 |
[snappyHexMesh] Parallel meshing - SnappyHexMesh | Akanksha90 | OpenFOAM Meshing & Mesh Conversion | 3 | March 3, 2022 07:52 |
[blockMesh] Parallel meshing strategy of a (very) simple case | ThibaultGET | OpenFOAM Meshing & Mesh Conversion | 1 | September 9, 2021 05:56 |
The problem when i use parallel computation for mesh deforming. | Hiroaki Sumikawa | OpenFOAM Running, Solving & CFD | 0 | November 20, 2018 02:58 |
Parallel meshing using XP64 with PVM in CFX Mesh | Huw | ANSYS Meshing & Geometry | 4 | July 12, 2010 10:24 |
