May 21, 2013, 13:14 |
XY plot, temperature and time
Torbjørn Stensrud
Rep Power: 13 |
I'm trying to make a new plot that has time on the x-axis and temperature on the y-axis.
It is a transient simulation. Somehow when I add this plot, the graph looks like this: http://i.imgur.com/bt5uUm1.png Now the simulation has been running for almost 500 minutes, the part I use in this plot has an initial T=300K and by the end it's at T=369K. How come my plot looks like this? |
May 21, 2013, 21:47 |
Abdullah Karimi
Rep Power: 15 |
Look into the edit plot menu and see if you selected the correct part. Also look into X-type and Y-type and units. If the part is a line, you should make sure that you are using the correct 'direction' in the position option of plot edit for y-type.
May 22, 2013, 06:56 |
Torbjørn Stensrud
Rep Power: 13 |
Both X and Y-axis are scalar values and thus there shouldn't be a direction to worry about, should it? The part I'm using is a solid cylinder and I'd like to see a plot on how it's average temperature changed during the simulation.
May 22, 2013, 08:49 |
Abdullah Karimi
Rep Power: 15 |
Did you start the report in the beginning? otherwise it would not have history.
May 22, 2013, 13:35 |
Ryan Coe
Rep Power: 15 |
I don't think you want whatSTAR-CCM+ calls an "XY plot." If you:
1. make a report that get's the temperature you're interested (may use a point probe for this) 2. make a monitor that runs that report every time-step 3. make a plot that includes that monitor 4. run your simulation from the beginning That should give you the result you're looking for.
Ryan |
April 18, 2015, 16:17 |
sanjeet Limbu
Rep Power: 11 |
hi I am tryinfg to get the maximum temperature for the mesh zone
how to get it |
Temperature Vs time Plot | Bikash | FLUENT | 9 | February 26, 2017 22:00 |
[OpenFOAM] plot temperature vs time in paraview - chtMultiRegionFoam | phsieh2005 | ParaView | 2 | March 16, 2014 06:50 |
Plot temperature vs time for a defined point | FREDERIK | FLUENT | 0 | August 26, 2005 05:49 |
Plot temperature versus time | Silke | FLUENT | 0 | August 15, 2005 10:12 |
