Issue in simulation of open channel flow with high viscosity fluid |
July 20, 2015, 12:42 |
Mohammadreza
Hi ,
I am trying to simulate the flow of a high viscous fluid (about 1-10 Pa-s) in an open channel. I made the model and ran it for the case of water at first and the software was able to converge the simulation easily. However, by increasing the dynamic viscosity to the real value for my fluid which is about 1-10 Pa-s, it can not converge the model for some reason. Anyone had this problem before ? I really need to know what I can do for high viscous fluid simulation in open channels. Thanks a lot |
December 2, 2017, 09:41 |
Rep Power: 9 |
I think this is because you are using an explicit scheme for time advancement.
You can try to use an implicit time scheme. |
December 3, 2017, 01:44 |
Rep Power: 24 |
You have to give more information. How do you know it's not converging?
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
Open channel flow with submerged outlet | Fonta | Fluent Multiphase | 0 | September 30, 2013 08:04 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
