6-dof
Old   July 25, 2015, 16:53
Default 6-dof
tuvia milshtein
sarahtuvia is on a distinguished road
Hi
Im calculating a motion of a body using the DFBI Rotation and Translation and
Id like to see on the scalar scene the movement of the body relative to the laboratory reference coordinates. No luck. The examples in the tutorials didnt help. Anyone can ?
sarahtuvia is offline   Reply With Quote
Old   August 26, 2015, 05:17
Pablo Mtz. Filgueira
pablo_fil is on a distinguished road
Hi!!
You can do it doing the same as the vortex shedding solution recording and playback tutorial, as it is an unsteady case.
Hope it helps!
pablo_fil is offline   Reply With Quote
Old   October 2, 2015, 06:53
tuvia milshtein
Hi everybody
Im tring to simulate a 6DOF trajectory of a very small particle moving in a chamber with two opennings, one with low pressure and the other with high pressure. Im using the overset mesh and everything goes ok while the particle is in the flowstream inside the chamber. But when he particle reaches the chamber walls the program stops with an error message:
"Failed to cut hole in region AAAA. This might be due to an overlapping of overset regions"
I activated the "Close proximity" and it didnt help.
Is there a way to let the particle move back to the flow stream after it reaches the wall ?
Thanks
Old   October 2, 2015, 06:55
You should use discrete element method. Overset mesh is not suitable for that purpose
Old   October 2, 2015, 09:38
tuvia milshtein
Thanks . Ill try it
coupled motion using six dof udf but with restraints fluentuser2003 Fluent UDF and Scheme Programming 0 September 4, 2012 15:51
Force can not converge colopolo CFX 13 October 4, 2011 22:03
The concept of DOF in fluid mechanics and CFD bearcat Main CFD Forum 8 May 27, 2007 18:02
help required in using six dof solver in fluent Shah FLUENT 1 February 25, 2006 11:31
Six dof UDF Dr. John Anttonen FLUENT 0 February 22, 2002 14:47
