August 15, 2015, 18:05 |
Could not connect scene graph socket problem
i have a problem, while starting or loading a simulation this warning appears: could not connect scene graph socket to MyPC:47827 from 192.168.1.12 I ve already installed this ccm to other two laptops and it worked perfectely. I just bought a new laptop and this happened. Its running on Windows 8.1 Please,can anyone help? |
November 4, 2015, 17:23 |
Could not connect to scene graph socket
Hey tjanosik,
i've got the same problem and cant figure out how to fix it. Did you find a solution? Best regards |
August 10, 2016, 10:14 |
Hey,
yes it worked for me but now after reinstaling windows same problem appeared. Have you solved yours? |
August 12, 2016, 05:33 |
Hey,
yes i have fixed the Problem, it was my connection to the Internet, i am not sure why, but it appears that i cant use the Programm with my LAN cable plugged in. When i used my Wifi the Programm just worked fine. I hope this may help you. |
November 19, 2016, 09:36 |
André van der Walt
Hey guys, any luck on further fixing the problem? My newly installed StarCCM+ does not want to work, because of this problem. I am running Windows 10 and StarCCM+ 11 with a POD licence. I have changed my internet connection 3 times already, all on WiFi.
Kind regards |
February 16, 2017, 15:54 |
Jørgen Tønne
Hey.have you found a way to solve the problem?
Jørgen |
February 17, 2017, 01:08 |
Graph Scene socket issue
André van der Walt
Hey Jørgen,
I have fixed my problem, it seems like it was some antivirus program that was pre-installed on my laptop that caused the isssue where the antivirus blocked Star-CCM+ to comunicate through the firewall. The unfortunate thing is that once the program starts to show these symptoms it makes a restore point in the installation somewhere and I couldn't find that. The solution I had to do is reset my laptop (basically format and reload Windows), in some cases UNINSTALL said antivirus before installing Star-CCM+ and then only will the issue be resolved. Regards |
natural convection problem for a CHT problem | Se-Hee | CFX | 2 | June 10, 2007 06:29 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Periodic flow boundary condition problem | sudha | FLUENT | 3 | April 28, 2004 08:40 |
extremely simple problem... can you solve it properly? | Mikhail | Main CFD Forum | 40 | September 9, 1999 09:11 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
