How to check our streamline simulation is right or not? |
September 22, 2015, 03:37 |
Aldias Bahatmaka
Rep Power: 10 |
Hello everyones,
Finally i could make the simulation for my ducted propeller, but i have other problems, In my results of streamlines, the water was rotating in nozzle only, and i still confuse about the function of interfaces region, in this thread, i attached the figures of ducted result, blades result, and the motion input, because in the simulation, i couldn't modify my motions specification being rotation, and how to solve it? need help. |
September 22, 2015, 09:31 |
Rep Power: 24 |
You likely can't modify the motion because you have a steady-state simulation prepared. Motion only applies to transient cases.
What confuses you about the interfaces? |
September 23, 2015, 00:22 |
#3 | |
Aldias Bahatmaka
Rep Power: 10 |
i am confusing about interface, how to know the right size for our interface, for example, my diameter propeller 130mm. and how if we don't use interface? is it problem for the result? |
September 23, 2015, 00:28 |
Rep Power: 24 |
Well, you are plotting streamlines of velocity in a rotating frame, that's probably why they look wrong. If you are in a rotating frame you need to view either relative velocity or velocity relative to the given frame.
I don't understand your interface question still. What do you mean the size of the interface? Do you mean 'how far away should the interface be from my geometry of interest?' If so, in general it should be relatively far, enough so the important flow structures are carried in the interface for MRF. If you are doing RBM, the location of the interface is arbitrary, although is beneficial for it to be not massive, as rotating a lot of cells is costly. |
Display Modes | |
restarting paused transient simulation using reactingFoam | JMDag2004 | OpenFOAM Running, Solving & CFD | 1 | August 10, 2015 10:15 |
Can someone check my BCs for p & U for a 3D aerofoil simulation, please? | pizzaspinate | OpenFOAM Pre-Processing | 7 | February 19, 2015 09:55 |
Grid independence check in transient simulation | abhi084 | Main CFD Forum | 1 | December 4, 2014 15:55 |
interrupt the simulation, check results, continue simulation | soulsaver | Phoenics | 1 | June 28, 2013 01:15 |
How to check the time taken by my Simulation?? | cfdsimulator | FLUENT | 4 | June 5, 2013 05:19 |
