December 20, 2020, 15:14 |
passive scalar
OK
Rep Power: 5 |
Hello all
how to activate the passive scalar in ccm+ ..... my study is about a ventilation system with two gases (air and CO) it is my first time to simulate something like that so I will appreciate any info Thank you |
December 20, 2020, 20:47 |
Chaotic Water
Rep Power: 17 |
The topic is very well described starting page 3608 in the section which is surprisingly called "Passive Scalars".
December 21, 2020, 15:35 |
OK
Rep Power: 5 |
Thank you sir
should I use it in multiphase or single phase ? |
December 27, 2020, 02:40 |
Ping
Rep Power: 20 |
you have stated that you have two gases in your simulation and so this means it is a simple single phase physics of gases.
the passive scalar is simply like a die you are adding somewhere does not affect the physics selections |
December 27, 2020, 03:58 |
OK
Rep Power: 5 |
That is clear Sir .... thank you for reply
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 04:18 |
Division by zero exception - loop over scalarField | Pat84 | OpenFOAM Programming & Development | 6 | February 18, 2017 05:57 |
Issue symmetryPlane 2.5d extruded airfoil simulation | 281419 | OpenFOAM Running, Solving & CFD | 5 | November 28, 2015 13:09 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 06:20 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
