Modelling the Restitution-Coefficients including the Weber-Number |
December 10, 2015, 04:16 |
Nils
Rep Power: 10 |
I try to model wall impigments in a lagrangian multiphase flow. So I defined a fieldfunction for my normal- , tangential restitution coefficients and the Weber-Number. Weber-Number: ${TrackParticleDensity}*pow($${TrackParticleVeloci ty}.mag()*sin(${TrackParticleIncidenceAngle}),2)*$ {TrackParticleDiameter}/0.035 Normal-Restitution (${WeberNumber} < 1.31) ? 1 : (1.1 * pow(${WeberNumber},-0.36)) Tangential-Restitution ($${TrackParticleVelocity}.mag()*cos(${TrackPartic leIncidenceAngle}) < 0.11) ? 0 : 0.862-0.094/($${TrackParticleVelocity}.mag()*cos(${TrackPartic leIncidenceAngle})) I have already selected the TrackFile with: Particle.Diameter, Particle.Density, Particle.Velocity (Incidence Angle is not allowed) Boundary Sampling: Particle.Density, Particle.Diameter, Particle.IncidenceAngle, Particle.Velocity When I run the simulation, the following error message occurs: Unable to compute field function TangentialRestitution on parcels of Lagrangian Phase: Phase1. Please check that function is defined here. So far so good: Now I have tried to select the incidence angle on my TrackFile, because this is the missing parameter for my field function (even if the incidence angle needs something like a boundary to interact...) like I expected the following error occurs: Function "Particle Incidence Angle" is not available to the TrackFile model in Lagrangian phase "Physics1: Phase1" By the way, I can display those fieldfunctions in a scalarscene on a boundary which is selected for the boundary sampling. But they are not defined on my Lagragian Phase. How can I solve this problem? Are there any existing approaches? Thank you for your support! Nils |
December 11, 2015, 09:05 |
Nils
Rep Power: 10 |
The problem has been solved.
It sounds simple: Weber-Number: ${ParticleDensity}*pow($${ParticleVeloci ty}.mag()*sin(${ParticleIncidenceAngle}),2)*$ {ParticleDiameter}/0.035 Normal-Restitution: (${WeberNumber} < 1.31) ? 1 : (1.1 * pow(${WeberNumber},-0.36)) Tangential-Restitution: ($${ParticleVelocity}.mag()*cos(${ParticleIncidenc eAngle}) < 0.11) ? 0 : 0.862-0.094/($${ParticleVelocity}.mag()*cos(${ParticleIncidenc eAngle})) gives the right coefficients. I thought that I necessarily have to use the Track-Parameters, because the IncidenceAngle is defined as an interaction between my LagrangianPhase and the boundary... however, using the normal particle paramaters work quiet well. |
[ImmersedBoundary] Immersed Boundary Method in OpenFOAM-3.1-ext | miladrakhsha | OpenFOAM Community Contributions | 106 | July 3, 2023 10:26 |
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
simpleFoam parallel | AndrewMortimer | OpenFOAM Running, Solving & CFD | 12 | August 7, 2015 18:45 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 08:14 |
Cluster ID's not contiguous in compute-nodes domain. ??? | Shogan | FLUENT | 1 | May 28, 2014 15:03 |
