Pressure Outlet - Effect of domain
Old   March 24, 2016, 04:20
Default Pressure Outlet - Effect of domain
Bineet Mehra
bineet_aero is on a distinguished road
Hello
I am modeling a conjugate heat transfer problem in STARCCM.
Inlet - Velocity Inlet
Outlet - Pressure Outlet
Flow - Laminar, Low R, Steady
As i change the distance between the trailing edge of the fin and outlet, P-inlet keeps on changing. I started with very small distance between Trailing edge of fin and outlet and then kept on increasing it. I did 6 simulations with different distance between Trailing edge of fin and outlet. I expect constant P at inlet after some value of this distance between Trailing edge of fin and outlet but its not the case. Aim is to get pressure drop. The lateral boundaries around outlet are symmetry planes. There is no recirculation at the outlet.
Any Suggestion ? Help
Thanks
bineet_aero is offline   Reply With Quote
Old   March 24, 2016, 15:37
Matt
fluid23 is on a distinguished road
Generally speaking, you should always place your boundary conditions far enough away that they do not impact your measurement. When you say that you did 6 sims and never saw this value flatten out, are you sure that you ever got 'far enough' away?
There are some exceptions to this rue and without seeing your geometry I can only speculate, but my guess is what you feel is far enough in reality is too close.
fluid23 is offline   Reply With Quote
Old   March 30, 2016, 05:30
Bineet Mehra
Thanks MBdonCFD for the information. I shall do some simulations with increased domain length for the outlet section. Will let you know.
Thanks
Old   April 5, 2016, 04:51
Smile
Bineet Mehra
The distance from Trailing edge of the fin and the outlet section was not enough. P at inlet not changing now for distance between TE of fin and outlet section more than 4L, L is the length if the fin.
Thanks
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 10:40
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
the static pressure at one outlet is negative? yuhehuan Main CFD Forum 7 August 15, 2013 21:01
pressure inlet & outlet. help ASAP Plz engahmed Main CFD Forum 0 June 13, 2010 15:34
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
