June 13, 2016, 12:22 |
Maximum parcel count exceeded
tuvia milshtein
Rep Power: 11 |
Hi
Im running a case with a large number of particles and it stops with the message: Unable to stamp 992424 new parcels. Maximum parcel count exceeded. Whats the meenning of it and how can I get over it ? Thanks |
June 13, 2016, 16:46 |
Matt
Rep Power: 17 |
I believe there is a setting under Solvers > Lagrangian Multiphase that will allow you to change the max parcel count allowable.
The parcel count is simply the number of particles in a parcel and the limit is a computational safety valve of sorts. The Lagrangian solver can take a very long time in some cases and not having a limit can result in your solution dragging out much, much longer than you hoped for. |
June 13, 2016, 18:30 |
tuvia milshtein
Rep Power: 11 |
Thanks, but I can not find in solvers > Lagrangian Multiphase any limit of the particles number. Could you instruct me more specificly where can I find it ?
June 14, 2016, 09:20 |
Matt
Rep Power: 17 |
Perhaps I was mistaken. I do not see it either.
June 14, 2016, 09:36 |
tuvia milshtein
Rep Power: 11 |
Thanks anyway
November 16, 2022, 08:13 |
Valparaiso
Rep Power: 6 |
I have same error in DEM model, could you fix it?
Maximum number of iterations exceeded - rhoSimpleFoam | don6alfonso | OpenFOAM Running, Solving & CFD | 3 | March 29, 2017 08:21 |
Partition: cell count = 0 | metmet | FLUENT | 1 | August 31, 2014 19:41 |
rhoPimpleFoam: Maximum number of iterations exceeded | gxy200992243 | OpenFOAM Running, Solving & CFD | 6 | July 12, 2014 10:52 |
Diverging solution in transonicMRFDyMFoam | tsalter | OpenFOAM Running, Solving & CFD | 30 | July 7, 2014 06:20 |
compressible flow in turbocharger | riesotto | OpenFOAM | 50 | May 26, 2014 01:47 |
