Wave Generator/Wave level Problem
2 Attachment(s)
Hello Guys,
i study Bachelor of Engineering in the 6. Semester and i have a problem with my CFD Project. I hope someone can help me. I have to simulate an Wave Generator. See the Pictures i have uploaded. My first question is how to fix a point on a isosurface? The isosurface is the border between air and water. Currently i have a little Ball wich is swimming on the water. The Z Posiotion is visualiezed in a report/plot. The first problem is that the Ball canīt show the exact high of the wave because it has a mass inertia. The next Problem you can see on the second picture. Seems like the water level increases steadily. This isnīt possible. I have no Inlet in my simulation. I donīt know how the water level can increase! The waves are generated by Morphing the left wall. Look at the Video. https://www.dropbox.com/s/n8g2lh4ww0...55_40.avi?dl=0 The thing at the right site of the pool is to damp the waves. I dont want to have a reflection from the right wall of the pool. |
Nice problem the only advice I can give is to create a field function
$Volume*$VolumeFractionWater*$DensityWater Create a sum report and monitor this field function it should remain constant like you said, if not perhaps you are not converging each time step enough |
You mean that i should create one Field Function with this Definition? Iīve done this so far and i start it now simulating. Showing the result in a few hours. |
1 Attachment(s)
Its not constant :(
My Time Step is 0,01s with 5 inner Iterations. The Amplitude is 20mm and the rotations speed is 60/min -> Omega 6,283 |
OK I would try cutting the time step in half, leave the 5 inner iterations and see if it cuts in half or just changes how your mass is changing.
silly question I know, but just double check the system is close If it is a closed system it might be important where you fix the pressure or increase the top of your domain and put a pressure boundary there |
1 Attachment(s)
The System is close. Now i try it out with a pressure outlet at the top of the Pool. |
No Changes with an Pressure Outlet at the top of the pool.
Anyone has another idea to fix this problem? |
