Surfaces Partially Coincident
2 Attachment(s)
I am new to Star CCM +. I am just following instruction from my professor gave the class. But I get this error has seen in the picture. This error appears after I execute the Badge for 2D Meshing. I have redrawn the figure three times because I thought it had something to do with my drawing. I drawn a couple of different lines to represent different surfaces. It is suppose to be a classroom with two windows and two vents. The windows have convection while the vents have heat flux. I need to keep the room at 20 degree C.
Thank You for any help or assistance with this problem. |
have you split part surfaces properly? it looks like you have one of the edge surfaces still attached to your z=0 geometry... remember, it can only create a badge for surfaces coincident with z=0 so if part of that surface deviates from that plane then you will see this warning.
How do I split the surfaces ?
go into geometry > parts > surfaces and right click. Then select split by patch....
this should allow you to make the various surfaces independent of each other by simply clicking. |
You should check out the help manual, it will give you much more detailed instructions.
I have tried everything I can't figure what I am doing wrong. It is just a simple 4 by 8 meter surface that is 0.2 m thick. I followed the examples like we did in class and still no results. I am thinking it is something in my drawing that I am doing wrong. I am drawing it on the XY plane and just extruding it 0.2 m. Do you have any suggestions ?
Make sure you are naming all of the part surfaces. This error indicates the code can't make a 2D domain because one of your part surface shares a name with one that is on the z=0 plane.
That is what it was. Thank you for your help. I wished you had told me that two days ago.:D
At least now I know more about after going through a rigorous of trouble shooting. |
